全模組 80 PLUS Gold 數位電源供應器
V850 Gold i | 全模組 80 PLUS Gold 數位電源供應器
V850 Gold i 數位 ATX 3.0 電源供應器可透過監控軟體提供實時監控和自訂風扇轉速曲線設定檔。全模組化線材、80 PLUS Gold 認證轉換效率、135mm靜音風扇和 10 年保固,這是您下一台電腦可選擇的完美 PSU。
MAKE IT DIGITAL
An indispensable digital power supply in the digital age, in addition to its excellent hardware design and materials, coordinate MasterPlus+ the platform to let you manage power more effectively.
THE FUTURE STARTS NOW
This power supply unit contains a semi-digital platform. This allows you to connect the PSU directly to the motherboard via an included USB 3.0 cable.
THE POWER IS YOURS
With the digital platform you can monitor performance in real time, tracking details such as fanspeed, temperature, and current load. You can even get readouts of performance data collected over time. Make the most of your PSU by taking control of it directly.
FULLY SUPPORT ATX3.0
Compliant with ATX3.0 standard and 12VHPWR connector, the V Gold i can support the peak power up to 200% more than rated power.
135mm silent fan
BUILD YOUR WAY
BUILT TO LAST
PSU CALCULATOR
