小巧而強悍
V SFX Gold 850 ATX 3.0 全模組 SFX 電源供應器
V SFX Gold 850 ATX 3.0電源供應器提供全模組線材、80 PLUS金牌認證效率、高度靈活耐用的90度線材、ATX轉接支架、100%日本製電容和10年的保固。點擊此處了解更多關於為什麼這款電源應該成為您的下一個mini-ITX主機建構的電源。
SMALL BUT MIGHTY
As the leading SFX power supply design, the V SFX Gold offers a highly powerful unit in a space-saving, mini form factor.
FLEXIBLE COMPATIBILITY
With the included SFX-to-ATX bracket, the V SFX Gold ATX 3.0 can be used to power systems ranging from as small as a mini-ITX all the way up to E-ATX motherboards.
80 PLUS GOLD CERTIFIED
The V SFX Gold is certified to achieve more than 90% efficiency at typical loads.
90-DEGREE 12VHPWR CABLE
HIGH-QUALITY JAPANESE CAPACITORS
Large, high-quality Japanese capacitors feature inmproved efficiency and reduced ripple noise.
FULLY MODULAR CABLING
PSU CALCULATOR
