Silencio Design
The Silencio’s minimalistic design cloaks its complexity. Design elements fine-tuned in form and function result in minimized noise and efficiently maintained system temperatures.
Silencio 是一款不用向散熱效能妥協的靜音機殼。主機由隔音材料環繞,所有風扇都配有橡膠緩衝墊,上方面板可拆卸的遮罩能夠阻隔噪音。Silencio S600 也同時提供強化玻璃或是帶有隔音材料的金屬側板型號供選擇。對於效能有所要求的平台,可移除上方面板的隔音遮罩增加通風。
For an even higher demand for ventilation, the top panel’s Sound Dampening Cover can be removed for unrestricted ventilation. An optional dust filter for the top panel ventilation is included, allowing the top panel and front panel to work in conjunction to cool the system.
Mini-ITX, Micro-ATX, ATX
Fan
Radiators
Top:
120 / 140mm x 2 Fans
120 / 240mm* Radiator
*remove ODD cage
35mm max motherboard component height
Front:
120 / 140 / 240 / 280 Radiator
Rear:
120 x 1 Fan
120 x 1 Radiator
5.25” ODD x 1 (ODD version)
3.5” HDD x 4
2.5” SSD x 5
CPU Cooler (Steel): 167mm
CPU Cooler (TG): 166mm
Power Supply: 180mm
Graphics Card: 398mm
