經典進化 全面之選
SickleFlow 120 ARGB 3 in 1 白色版本
承襲SickleFlow 120系列,酷碼推出新一代系列產品,藉著各種全新特色帶來明顯的效能提升。在光效的表現不但更勝以往,也已經在各大主機板品牌中完成連動燈效的認證。全新的SickleFlow 120針對扇葉曲面有了進一步優化。 強化的風扇框架,增加了框架支撐力度,有效降低擾流以及噪音的產生。
SickleFlow 120 ARGB White Edition, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
Enhanced Fan Frame
Sealed Bearing Structure
New Blade Design
Secure Connection
Includes Addressable RGB connector clips to ensure a secure connection
Addressable RGB Controller
With Included Addressable RGB Controller, You can choose your favorite color easily. It also support lighting RESET button of Case.
