大顯神通
MasterAccessory PCIe 4.0 x16延長線 200mm V2
Cooler Master PCIe 4.0 x16 的延長線線材採用超柔韌的橡膠護套,安裝更簡單更方便。
FLEX YOUR GRAPHICS MUSCLE
AVAILABLE IN BOTH BLACK AND WHITE COLORATIONS
Cooler Master's premium PCIe4.0 Riser Cables V2 are available in both BLACK and WHITE so you can choose the color that best matches your setup!
PCIE 4.0 COMPATIBLE
HEAVY DUTY SHIELDING
GOLD-PLATED PIN CONNECTIONS
NEW PROTECTIVE ABS CASING
NEW ULTRA-FLEXIBLE CABLE SLEEVES
FLEX YOUR GRAPHICS CARD MUSCLE
The Cooler Master Riser Cable PCIe 4.0 x16 V2 is designed for greater data transmission efficiency, maximum flexibility and durability. High quality plastics grant increased cable flexibility and strength for the tightest PCI card installations, while the heavy-duty shielding prevents electromagnetic interference from degrading signal quality.
The multi-layer coated PCB provides the best-in-class cable flex, moisture resistance and performance under high thermal loads.
