The redesigned dust filter keeps your PC breathing easy
with a refreshed patterned design.
USB 3.2 Gen 2x2 Type C port built into the I/O panel with data transfer speeds up to 20Gbps.
Q300L V2以推動微型ATX機殼的極限為目標,為小型機殼的組裝體驗帶來全新感受。
Design
Show off your build through the 4mm-thick tempered glass side panel, easily installed with thumbscrews.
The case can be put in vertical or horizonal position.
The front supports up to two 140mm fans and up to a 240mm radiator. The rear supports a 120mm fan or radiator and the top two 120mm fans. All to ensure you don't have to compromise on performance.
The Q300L V2 case supports CPU coolers up to a height of 159mm, graphics cards up to a length of 360mm, and power supplies up to a length of 160mm.
