80 PLUS 銅牌認證電源供應器
MWE 450 Bronze - V2 銅牌 450W 電源供應器
MWE Bronze 通過 80 Plus 銅牌認證,能確保典型負載轉換效率平均達 85%,DC-DC 搭配 LLC 電路設計讓設備能可靠、安全、有效率的由 12V 單路供電取得需要的電源,提供更好的整體使用體驗。電源供應器在待機或是低負載作業時能以靜音模式運作。
POWER UP
The MWE Bronze offers a simple, reliable way to power your mid-range system safely and efficiently. The 80 PLUS Bronze efficiency rating, DC-to-DC circuit design, discrete cables, silent mode, and 120mm HDB fan offer a power supply unit that's solid in features and performance while remaining simple. This PSU will handle all your core computing needs with none of the hassles or challenges of additional specialty features, software synchronization, or other bells and whistles. Just plug the cables you need into your components and get to work. For a great computing experience, you can’t go wrong with the MWE Bronze.
80 PLUS BRONZE EFFICIENCY
DC-TO-DC CIRCUIT DESIGN
120MM HDB FAN
ACTIVE POWER FACTOR CORRECTION
TECH SPECS
CABLE LENGTH & OUTPUT RATING
FLAT, BLACK CABLES
