高導熱效能散熱膏
MasterGel Pro V2 高導熱效能散熱膏
MasterGel Pro V2是升級版本,含有升級的聚合物,具有較高的CPU / GPU熱傳導效能,可提供更好的散熱並改善從晶片組到接觸面的熱傳遞。除了美觀的設計外,還對導熱係數進行了調整,以適應您從常規到進階的各種性能需求。
MasterGel Pro V2
HIGH THERMAL CONDUCTIVITY COMPOUND
Upgraded compound for better heat dissipation
High CPU/GPU conductivity (9 W/m.k)
Improves heat transfer from chipset to cooler base or heat pipes
Easy to spread and remove without damaging the surface
High Performance
Upgraded compound improves heat transfer from chipset to cooler base or heat pipes
High Quality
MasterGel Pro V2, an upgraded compound of its old version with high CPU/GPU conductivity, providing better heat dissipation as well as improving heat transfer form chipset to cooler base. Apart from aesthetic design the thermal grease has been adjusted to match your performance needs.
Easy To Spread
W/M.K = 9
