雙環世界
MasterFan MF120 Halo² White 3in1 機殼風扇
MasterFan 120 Halo系列廣受市場歡迎後不久,Cooler Master推出了重新設計的雙光環系列風扇,名為MasterFan MF120 Halo²。MF120 具有 10% 更大的風扇葉片以提高空氣流動和散熱性能。框架採用混合結構設計保持穩定性而不犧牲空間。
A DUAL NEW WORLD
The MasterFan MF120 Halo² is our redesigned dual loop LED series fan, now available as a 3-in-1 pack, giving you triple the cooling power. The MF120 features 10% larger fan blades for improved air flow and cooling performance. The frame has been designed with a hybrid structure that maintains stability without sacrificing operational real estate. An upgraded driver IC is also included for increased cooling performance and minimal fan noise, while the elegant dual loop LED design is maintained via addressable gen 2 RGB lighting that provides the ultimate customizable experience. Enter a dual new world with the the MasterFan MF120 Halo².
HYBRID FRAME DESIGN
A hybrid frame structure maintains stability without sacrificing fan blade size or performance.
LED CONTROLLER
UPGRADED DRIVER IC
An upgraded driver IC boosts cooling performance while minimizing fan noise.
