Hyper 622 Halo 黑色
Cooler Master推出Hyper系列新品,6導熱管設計的Hyper 622 Halo黑色版。
ARGB AUTO DETECTION
Intuitive LED detection automatically provides default ARGB spectrum lighting or full ARGB customization via 3-pin header connection.
DUAL REDESIGNED HALO² FAN
Dual loop LED 120mm Halo² fan features stunning lighting with improved fan performance,
DUAL TOWER HEAT SINK
Dual tower heat sink and dual fans deliver twice the surface area for superior cooling.
PERFORMANCE HEAT PIPES X 6
Complete CPU coverage nickel-plated base with 6 uniform heat pipes transfers heat evenly and quickly
BROAD CASE FITMENT
Low profile heat pipes optimized at 157mm height accommodates most RAM and case requirements
HIGH PERFORMANCE CRYOFUZE
Utilizing nanoparticles, CryoFuze allows for excellent thermal conductivity on all processing components for optimal heat transfer.
BLACK ALUMINUM TOP COVER
Upscale design featuring aluminum top cover and signature logo
CPU COMPATIBILITY
