80 PLUS Gold Efficiency
140mm Silent Fan
High Temperature Resilience
Fully Modular Cabling
10 Year Warranty
Cooler Master GX Gold 1250 ATX3.0 提供 80 PLUS 金牌的電源轉換效率、安靜的 140mm 靜音風扇、2 個 EPS 接口、完全模組化的線材和 10 年保固。了解更多有關於電源供應器的信息,以及為什麼它會成為您下一次組裝電腦或當前系統可靠升級的絕佳選擇。
140mm Silent Fan
10 Year Warranty
Cooler Master took the initiative and continuously developing our first ATX3.0 Power Supply lineup. Compliant with ATX3.0 standard and 12VHPWR connectors, the GX Gold 1050/1250 ATX3.0 can fully support the peak power drawn by the 40 series RTX graphic cards and whole system.
The GX Gold 1050/1250 ATX3.0 has improved to operate safely at up to 50 degrees Celsius ambient for high-end computer, overclocking and other high intensity applications. Such a high threshold greatly enhances the performance of your PSU and your system.
The fully modular version of the GX Gold 1050/1250 ATX3.0 comes with a set of flat black cables that can be customized to each user's individual needs. It's designed for easy cable management that each system only needs to include the cables required. This unused space within the chassis allows for reduced clutter, better airflow and aesthetic, thereby improving your system's overall cooling.
