New
Dyn X Motion System
Introducing the Cooler Master Dyn X Motion System: a leap forward in motion simulation, designed for sim racing, and flight simulation enthusiasts and professionals.
Feel Every Track Detail
With larger motors and actuators, our motion system supports more weight and delivers a powerful, torque-enhanced feel, making it ideal for commercial applications. As a highly reliable, industrial-grade system, it offers exceptionally realistic vehicle motion feedback through advanced signal processing. Experience every elevation change, vehicle movement, surface change, and gear shift with unparalleled fidelity.
Professional Motion System
Provides exceptionally realistic vehicle motion feedback.
DYN X ACTUATOR MOUNT FEATURES
Haptic Feedback
Broad Compatibility
Electronic Mounting Tray
Simple And Easy Installation
Responsive actuator travel
Features 2” (50mm) of possible travel.
Rugged Construction
A piston featuring an especially large diameter and a machined billet with aluminum housing have been built to last.
Large weight capacity
Supports up to 800 lbs. (363 kg).
