Nguồn kỹ thuật số Full Modular chuẩn 80 PLUS GOLD
V850 Gold i multi Fully Modular 80 PLUS Gold Digital Power Supply
The V850 Gold i multi digital ATX 3.0 power supply unit from Cooler Master delivers real time monitoring and fan curve customization
MAKE IT DIGITAL
An indispensable digital power supply in the digital age, in addition to its excellent hardware design and materials, coordinate MasterPlus+ the platform to let you manage power more effectively.
THE FUTURE STARTS NOW
This power supply unit contains a semi-digital platform. This allows you to connect the PSU directly to the motherboard via an included USB 3.0 cable.
THE POWER IS YOURS
With the digital platform you can monitor performance in real time, tracking details such as fanspeed, temperature, and current load. You can even get readouts of performance data collected over time. Make the most of your PSU by taking control of it directly.
FULLY SUPPORT ATX3.0
Compliant with ATX3.0 standard and 12VHPWR connector, the V Gold i can support the peak power up to 200% more than rated power.
135mm silent fan
BUILD YOUR WAY
BUILT TO LAST
PSU CALCULATOR
