Tempered Glass Side Panel
Tempered Glass Side Panel for MasterCase5, 6, MC500, MC600, H500P and H500M
Overview
The tempered glass side panel bring a premium touch to your chassis and allow to highlight any system from water cooling advanced build up to the simpliest configuration.
The quality of the glass guarantee a long life durability and the bracket design hold the side panel to prevent any falls.
Compatible with:
• MasterCase 5 Series
• MasterCase 6 Series
• MC500 Series
• MC600 Series
• H500P & H500M
Unique Bracket Design
Can hold the tempered glass from falling down while installing or removing.
Toughened Dark Black or Light Grey Tinted Glass
It provides 3 - 5 times more strength than regular glass because of the 4mm thickness.
Only see the subtle light effects inside your system.
The tempered glass can be choosen in 2 tinted colors : Light Grey or Dark Black
Easy Secure Design
Lock or unlock the glass side panel easily with a coin.
