SMALL BUT MIGHTY
As the leading SFX power supply design, the V SFX Gold offers a highly powerful unit in a space-saving, mini form factor.
ยูนิตจ่ายไฟ V SFX Gold 850 ATX 3.0 จาก Cooler Master นำเสนอสายเคเบิลแบบโมดูลาร์เต็มรูปแบบ ประสิทธิภาพ 80 PLUS Gold มีความยืดหยุ่นสูง
With the included SFX-to-ATX bracket, the V SFX Gold ATX 3.0 can be used to power systems ranging from as small as a mini-ITX all the way up to E-ATX motherboards.
The V SFX Gold is certified to achieve more than 90% efficiency at typical loads.
Large, high-quality Japanese capacitors feature inmproved efficiency and reduced ripple noise.
The page you're looking shows Cooler Master contents for ไทย.
