New
Illuminating Perfection
Universal Vertical GPU Holder Kit ARGB
ยกระดับการตั้งค่าการเล่นเกมของคุณด้วย Universal Vertical GPU Holder Kit ARGB และโดดเด่นในหมู่นักเล่นเกมคนอื่นๆ ปลดล็อกศักยภาพสูงสุดของประสบการณ์การเล่นเกมของคุณ
Rotatable ARGB Lighting
A 270° ARGB lighting strip curved with Cooler Master symbol offers style options from minimal to maximal illumination.
Ultra-flexible PCIe 4.0 Riser Cable Included
Ultra-flexible PCIe 4.0 riser cable enables high-speed data transmission with ease for tight cable routing.
Tool-less, Instantly Adjustable Design
Toollessly adjustable up to 65mm horizontally, as well as up to 30mm towards the side panel for easy installation.
Effortlessly Showcase Your Graphics Card
Bring the best out of your components by showing off your GPU.
ATX & M-ATX
COMPATIBILITY
Designed for both ATX and mATX cases, this accessory is compatible with the latest GPUs available on the market.
PCIe Slot Quick Release System
Enabling painless graphic card uninstallation for hassle-free upgrades and maintenance with the Quick Release System.
The Ultimate Solution For Vertical GPU Mounting
