Silence Has A Sequel
Silencio S600
Whether your hardware is configured for optimum silence, workspace efficiency, or gaming performance, the Silencio makes the best builds even better.
Silencio Design
The Silencio’s minimalistic design cloaks its complexity. Design elements fine-tuned in form and function result in minimized noise and efficiently maintained system temperatures.
Silencio Technology
Sound Dampening Material
Top
Ventilation
For an even higher demand for ventilation, the top panel’s Sound Dampening Cover can be removed for unrestricted ventilation. An optional dust filter for the top panel ventilation is included, allowing the top panel and front panel to work in conjunction to cool the system.
Ventilation
Reversible Steel Door
Silencio Fans
Motherboard Support
Mini-ITX, Micro-ATX, ATX
Cooling Support
Fan
Radiators
Top:
120 / 140mm x 2 Fans
120 / 240mm* Radiator
*remove ODD cage
35mm max motherboard component height
Front:
120 / 140 / 240 / 280 Radiator
Rear:
120 x 1 Fan
120 x 1 Radiator
Storage Support
5.25” ODD x 1 (ODD version)
3.5” HDD x 4
2.5” SSD x 5
Clearances
CPU Cooler (Steel): 167mm
CPU Cooler (TG): 166mm
Power Supply: 180mm
Graphics Card: 398mm
