MasterLiquid ML240 Illusion
MasterLiquid ML240 Illusion กำหนดนิยามใหม่ของการแสดงแสงด้วยฟีเจอร์การออกแบบใหม่ทั้งหมดใน MasterLiquid Series
The MasterLiquid ML-Illusion series redefines lighting visuals with all new design features to the MasterLiquid Series. With 12 Addressable Gen 2 RGB LEDs integrated into the all new translucent pump, the color options are spectacularly customizable. Complemented with MasterFan MF120 Halo fans lighting features are more than even visual enthusiasts can handle. The Illusion is not only elegant, but extremely capable as well, featuring the 3rd generation Dual Chamber Pump for excellent cooling performance.
TRANSLUCENT DOME
Stunning lighting visuals with translucent water chamber dome compatible with software customization
NEW 3RD GEN DUAL CHAMBER PUMP
Experience a quieter cooling performance with an improved design on the internal impeller and housing to enhance the cooling performance and efficiency while lowering the noise level.
EXPANDED DISSIPATION SURFACE AREA
Widened radiator water channels for increased cooling surface area.
MasterFan
MF120 Halo
Dual loop Gen 2 Addressable RGB fans with 24 individual ARGB LEDs Fully Customizable with MasterPlus+ software to ensure the most vibrant display of color
New Gen 2
Addressable RGB
Included Gen 2 ARGB controller works with Cooler Master’s MasterPlus+ software Customizing each individual LED in color, effect, brightness, and more – all from an intuitive, convenient interface
CPU COMPATIBILITY
