High Thermal Conductivity Compound
MasterGel Pro V2
MasterGel Pro V2 คอมปาวน์ที่ได้รับการอัพเกรดจากรุ่นเก่าที่มีการนำ CPU/GPU สูง ให้การกระจายความร้อนได้ดีขึ้น...
MasterGel Pro V2
HIGH THERMAL CONDUCTIVITY COMPOUND
Upgraded compound for better heat dissipation
High CPU/GPU conductivity (9 W/m.k)
Improves heat transfer from chipset to cooler base or heat pipes
Easy to spread and remove without damaging the surface
High Performance
Upgraded compound improves heat transfer from chipset to cooler base or heat pipes
High Quality
MasterGel Pro V2, an upgraded compound of its old version with high CPU/GPU conductivity, providing better heat dissipation as well as improving heat transfer form chipset to cooler base. Apart from aesthetic design the thermal grease has been adjusted to match your performance needs.
Easy To Spread
W/M.K = 9
