Visuais além dos limites
Tempest GP27Q Quantum Dot MiniLED Gaming Monitor
The Tempest GP27Q is designed for everyone and offers outstanding value and competency with Mini LED WQHD 165Hz.
A True Work and Play Monitor
With specifications perfect for both the working professional as well as the hardcore gamer, the Tempest GP27Q is a true do-it-all monitor. Equipped with a 2560 x 1440 resolution panel that covers 98% of the DCI-P3 color spectrum, and boasts 165Hz refresh rate with a 1 ms response time, this monitor can be the perfect centerpiece to your work and play setup.
Smooth Operator
Adaptive Sync is essential for maintaining a smooth experience when playing games. By synchronizing the frames outputted from your GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is smoother than ever.
Easy On The Eyes
Connection Master
Make It Your Game
Cooler Master Unique Design
Master Agility
With a wide range of adjustability, the Tempest GP27Q can be positioned to the way you want it exactly.
AMPLE Connectivity
2 x USB Type A
1 x Type B
2 x HDMI 2.0
1 x DisplayPort
1 x USB Type C (supports 90W PD charging output)
1 x 3.5mm Headphone Jack
