Dive Into The Gaming World
Tempest GP2711 Gaming Monitor
The Tempest GP2711 is a marvel of technology and is tailored to meet the high standards of avid gamers and demanding creative professionals.
YOUR PLAY-WORK-MOVIE SOLUTION
GP2711 delivers superior images and accurate colors with a more responsive overall experience making it perfect for work and play.
OPTIMIZED COOLING DESIGN
Featuring Cooler Master's unique heatsink and a thermal back cover design. the GP2711 ensures enhanced cooling without the need for fans. This reduces the main chip's temperature by “5°C, extending product durability by 30%. Experience unmatched temperature stability during long work or play sessions. Plus, benefit from our 4-year warranty.
HIGH CONTRAST, DEEP BLACKS
Our VA panel, with the latest Mini-LED technology, provides an ultra-high contrast visual experience in HDR. In HDR+ local dimming mode, it can achieve over 3,000,000:1 contrast*.
* Based on LAB testing
VA PANEL WITH MINI LED
While standard Mini-LED monitors suffer from low contrast and pronounced halo effects, the GP2711 offers high contrast with minimal halo problems.
SUPERIOR CONTRAST (3,000:1) & HDR 1000 (1500NITS PEAK)
The VA panel with mini LED in the GP2711 let you see the real world through the screen. Offer 3000:1 contrast ratio and HDR of 3,000,000:1 using local dimming. This far outpaces the average IPS monitor contrast of 1000:1 and no HDR. Up to 1000 nits of brightness make for sharp clarity in bright areas and rich details in dark areas.
TOTAL VISUAL BRILLIANCE
Using a quantum dot enhancement film, the GP2711 offers brighter, more vibrant colors with exceptional color reproduction, covering 93.5% of the Adobe RGB and 95% of the DCI-P3 color gamut ranges.
DETAILS APLENTY
The QHD resolution not only offers sharper visuals, but also provides more screen space, making multitasking a breeze and gaming more immersive.
SPEED AND PRECISION MPRI
GP2711 utilize a fast 165z panel along with an ultra-responsive 1ms (MPRT) / less than 4ms GtG response time that is carefully calibrated for optimal overdrive performance.
ULTRA-SMOOTH REALISM
FreeSync ensures smooth, lifelike gameplay that accurately reproduces a level of realism to everything you play. By synchronizing the frames outputted from the GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is smoother than ever.
DCI-P3 & ADOBE RGB SUPPORT
With extensive color gamut support, including DCI-P3 and Adobe RGB, the GP2711 is ideal for color-critical tasks.
ELITE-LEVEL COLOR ACCURACY
Our monitors are hand-calibrated at the factory, promising impeccable color reproduction with a delta E ≤ 2*. Witness content as the creator envisioned.
* sRGB mode
EASY ON THE EYES
With TUV Certificate hardware-enabled Low Blue Light Mode and Flicker-Free technology, the GP2711 is gentle on the eyes, minimizing fatigue as you get more work or gaming done.
CONNECTIVITY OPTIONS
Connect your devices with I/O ports consisting of:
• HDMI 2.0 x 2
• DP 1.4 x 1
• Type-C x 1 (DP Alt Mode & PD15W)
• USB Type-B 3.0 x 1
• USB Type-A 3.0 x 2
• 3.5 mm Audio Out x 1
• Speaker 2W x 2
