Escolha o máximo
SickleFlow 140 ARGB
SickleFlow 140 ARGB, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers...
SickleFlow 140 ARGB, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
Enhanced Fan Frame
Sealed Bearing Structure
New Blade Design
Secure Connection
Includes Addressable RGB connector clips to ensure a secure connection
