CRIE DO SEU JEITO
QUBE 500 Flatpack Black & White Edition
Introducing the all-new QUBE 500, a highly customizable flat pack case from Cooler Master that allows you to emphasize your own personal style
Fully Modular
Features modular panels that simplify and streamline the usual case
prep process. Every panel is separately removable for easy maintenance.
Flatpack Assembly
Besides the clear eco-benefits, we believe flat-packing will provide a fun and satisfying build experience.
Welcome to the future of PC DIY.
Swappable Side Panels
The symmetric design allows you to switch the steel panel and the glass panel with each other for a non-transparent build.
Highly Customizable
An unprecedented level of customizability allows for full creative expression.
Build as you unbox
From the moment you open the box, the build begin with fun and easy step-by-step instructions.
Full-sized specs
& pint-sized body
The Qube 500 can house almost anything you would expect from a larger case, from EATX Motherboards and the latest GPUs to dual 280mm radiators.
Hardware Compatibility
The Qube 500 is compatible with 280mm water coolers, 172mm air coolers, 173mm ATX PSUs, E-ATX motherboards and smaller, and 360mm GPUs.
Storage Compatibility
The Qube 500 provides up to 4x 3.5” HDD mounting positions and up to 3x 2.5” SSD mounting positions.
Mult-color Macaron edition
Color your way
Fully express yourself with the multi-color Macaron edition. It includes two sets of extra panels, an extra handlebar, and two accessory hooks (only available on Macaron edition models). Mix and match the modular panels to create a case that is truly your own.
Side radiator bracket
Extra Airflow
The side radiator mount has two positions, allowing you to install a 280mm radiator or provide your GPU with extra airflow.
GPU Bracket
Built-in vertical
Vertically mount your GPU with the included bracket. You can even adjust the distance from the side panel to maintain good airflow.
Accessory ecosystem
The Qube 500 comes with a living accessory ecosystem. A Gem mini cable manager and accessory hook are included (only available on Macaron edition models), and we have prepared some 3D-printable files for you to create your own accessories.
