Fonte de alimentação com certificação 80 PLUS Bronze
MWE 450 Bronze - V2
The MWE Bronze Full-Modular offers Bronze efficiency, DC-to-DC circuit design, a 120mm FDB fan, and semi-fanless operation up to 40% load.
POWER UP
The MWE Bronze offers a simple, reliable way to power your mid-range system safely and efficiently. The 80 PLUS Bronze efficiency rating, DC-to-DC circuit design, discrete cables, silent mode, and 120mm HDB fan offer a power supply unit that's solid in features and performance while remaining simple. This PSU will handle all your core computing needs with none of the hassles or challenges of additional specialty features, software synchronization, or other bells and whistles. Just plug the cables you need into your components and get to work. For a great computing experience, you can’t go wrong with the MWE Bronze.
80 PLUS BRONZE EFFICIENCY
DC-TO-DC CIRCUIT DESIGN
120MM HDB FAN
ACTIVE POWER FACTOR CORRECTION
TECH SPECS
CABLE LENGTH & OUTPUT RATING
FLAT, BLACK CABLES
