Mais equilíbrio, mais explosão
Mobius 120 Case Fan
Cooler Master is introducing the Mobius Series representing the performance line of fans with a new entry – Mobius 120.
PERFECTING ENGINEERING
Introducing the latest addition to Cooler Master’s critically-acclaimed Mobius case fan series, the Mobius 120 Black Edition. This version of the Mobius includes all the high-performance features of the classic Mobius, now in a blackout design. With our innovative ring blade design, loop dynamic bearing, oil reflow and anti-sway systems, and dust protection, the Mobius 120 Black is an aesthetically sleek take on a Cooler Master classic.
Pressure Acceleration Air Vents
Angled inner frame rim with chamfered side vents boost airflow draw, The structural ring blade eliminates any fan deformation- Ring Blade keeps the fan build structure rigid, inflexible, stiff and rigor 45 deg Q in and Q out, larger air flow in and air flow out increasing the Q
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
VARIOUS SPEEDS, VARIOUS FUNCTIONS
The Mobius Series offer various speeds for distinct usages. With the Mobius 120 operating up to 2050rpm, it is perfect for your case and chassis air intake. The Mobius 120P ARGB spins up to 2400rpm, designed to handle performance for air and liquid cooling.
