The Hyper H412R is an affordable, compact and high performance air cooler that is a great fit for small form factor system. With 4 heatpipes and Direct Contact technology, this outperforms its predecessor Hyper TX3 series. The special fin design optimizes air flow toward heatpipes. Its 92mm PWM fan features a wide fan speed range and can be fine tuned for maximum airflow and cooling performance or silent operation.
COMPACT and COMPELLING
Hyper H412R
Hyper H412R
4 Direct Contact Heatpipes
Performance in Compact Size
Easy Installation
Tool-free mounting system ensures hassle-free installation. Universal retention brackets are compatible with latest Intel and AMD socket CPU.
Perfecting the Heatsink Design
CPU COMPATIBILITY
DIMENSIONS
