The Hyper H410R is an affordable, compact and high performance air cooler that is a great fit for small form factor system. With 4 heatpipes and Direct Contact technology, this outperforms its predecessor Hyper 103. The special fin design optimizes air flow toward heatpipes. Its 92mm PWM fan features a wide fan speed range and can be fine tuned for maximum airflow and cooling performance or silent operation.
COOLER DE TORRE COMPACTO COM UM ÍMPETO
Hyper H410R
Hyper H410R
4 Direct Contact Heatpipes
Performance in Compact Size
Easy Installation
Tool-free mounting system ensures hassle-free installation. Universal retention brackets are compatible with latest Intel and AMD socket CPU.
Perfecting the Heatsink Design
