Entregando o que importa
GM27-FFS Flat Gaming Monitor
The GM27-FFS is designed for everyone and offers outstanding value and competency with FHD resolution that empowers your work/play experience
Ready for Any Situation
The 27" Full HD 165Hz display combined with 90% DCI-P3 wide color gamut makes the GM27-FFS an incredibly versatile monitor. With features essential for both gaming and productivity, you can have the freedom to play your games without a hitch or focus on your work
Ultraspeed IPS with Dynamic Overdrive
Equipped with the latest Ultra-Speed IPS panel, GM27-FFS is up to 4x faster than traditional IPS panels. The pixels transition faster to other colors and scenes, leading to an exceptionally smooth picture with significantly less motion blur or smearing.
Dynamic Overdrive is also specifically tuned for the GM27-FFS, automatically selecting the most optimal overdrive settings based on the refresh rate for an even smoother experience.
Smooth Operator
Adaptive Sync delivers smoother gameplay that accurately reproduces a level of realism to everything you play. By synchronizing the output frames from your GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is more fluid than ever.
Incredible Color Detail
Covering 90% of the DCI-P3 color spectrum and 120% of sRGB, the GM27-FFS accurately reproduces colors as the creators intended, enhancing your experience in games and entertainment.
Details Plenty
Full HD resolution is easier to drive in games, and offers a great balance between visual fidelity and performance for the price.
Make it Your Game
Easy on the Eyes
Protect your eyes from potentially harmful blue light with our Low Blue Light Mode. Our monitors are also Flicker Free, further reducing any eye strain and allowing you to get more work or gaming done.
Get Connected
Connect a multitude of devices to your monitor with 2 x DisplayPort 1.4 ports as well as 2 x HDMI 2.0 ports.
