SIMPLES AINDA PODEROSO
ERGOSTAND IV
ERGOSTAND IV
Ergostand IV
The Notepal ERGOSTAND IV is an ergonomic laptop cooling stand that will make using your laptop fun again. A 140mm silent fan with aerodynamic design keeps your laptop cool and working smoothly. 5 ergonomic height settings for comfortable viewing angles. The use of full mesh board improves its cooling performance greatly. A blue LED strip gives you the edge in the dark and 4 additional USB ports let you plug in all your devices.
Ergonomic Design
5 ergonomic height settings make sure you are always able to choose the right height for your viewing angle.
Full Mesh Board
Led Strip & Additional USB Hub
A blue LED strip helps you find the right keys on your keyboard and 4 additional USB ports give you all the flexibility to connect your devices.
Silent Cooling
A 140mm fan, designed for silence, keeps you laptop cool and working smoothly.
