X Silent Edge Platinum 1100 230V Power Supply
Awards
MUST HAVE
KitGuru
This is one of the best power supplies we have ever tested - it scores 9.5/10 and wins our Must Have award! It also ranks Number 1 in our 'Best of' categories.
INNOVATION
OC3D
Overall, we are impressed with the X Silent Edge. It remains cool under full load without active cooling, which is crazy for an 1100W power supply.
Precise Silent Power
Engineered with a fanless design and industrial IC components, X Silent Edge Platinum features out Heat Pipe.
Dissipation Patent, ensuring quietness for even the most noise-sensitive environments.
Innovative Design
NO FAN, NO DUST
Equipped with a heat pipe and an innovative modular thermal
structure, our design enhances thermal efficiency, essential for the
low-temperature rise of key components and the ultra-quiet fanless
operation.
FULLY MODULAR CABLING
Modular cabling minimizes clutter, while the additional ports
provide extra functionality.
Cooling System
HEAT DISSIPATION
Our Private Aluminum Thermal Mold effectively dissipates heat, and the Innovative Heat Pipe Thermal Tech uniformly regulates unit temperature. This ensures superior thermal control, enhancing efficiency and longevity in demanding environments.
Digital Power Management System & MasterCTRL
Equipped with MCUs and Integrated with MasterCTRL software, our reliable PSU meticulously monitors temperature, current load and efficiency in real-time, offering precise and direct oversight.
ACTIVE BRIDGE RECTIFIER BOOSTS EFFICIENCY 2%
The Active Bridge Rectifier, equipped with the Infineon CoolMOS, marks a significant advancement in power efficiency. This innovative combination not only conserves electricity, but also significantly reduces power loss, outperforming traditional bridge diodes. It's an ideal solution for users seeking eco-friendly, high-efficiency power supply units.
ATX 3.1 SUPPORT & A DURABLE 90° 12V-2X6 CABLE
Includes ATX 3.1 support and a 90° 12V-2x6 connector featuring more reliability, higher electrical durability, improved safety, and capable of bringing up to 600W to your GPU.
PSU Calculator
