작지만 강력한
V SFX Gold 850 ATX 3.0 Fully Modular SFX Power Supply
The V SFX Gold 850 ATX 3.0 power supply unit from Cooler Master offers fully modular cabling, 80 PLUS Gold efficiency, a highly flexible
SMALL BUT MIGHTY
As the leading SFX power supply design, the V SFX Gold offers a highly powerful unit in a space-saving, mini form factor.
FLEXIBLE COMPATIBILITY
With the included SFX-to-ATX bracket, the V SFX Gold ATX 3.0 can be used to power systems ranging from as small as a mini-ITX all the way up to E-ATX motherboards.
80 PLUS GOLD CERTIFIED
The V SFX Gold is certified to achieve more than 90% efficiency at typical loads.
90-DEGREE 12VHPWR CABLE
HIGH-QUALITY JAPANESE CAPACITORS
Large, high-quality Japanese capacitors feature inmproved efficiency and reduced ripple noise.
FULLY MODULAR CABLING
PSU CALCULATOR
