풀 모듈식 80플러스 골드 PSU
MWE Gold 1050 - V2 (Full Modular)
MWE Gold 1050 - V2 (Full Modular) is the next step in the evolution of Cooler Master's entry level 80 PLUS Gold power offerings.
Power Up
The new MWE Gold V2 1050, 1250 series is the next step in the evolution of Cooler Master's entry level 80 Plus Gold Power Supply line which improves upon the original version in the places where users will see the most immediate benefit in terms of performance and stability for high end pc requirements.
Quiet Cooling
Silence Fan with Smart Temp. Controlling Feature
MWE Gold 1050 & 1250 are equipped with a 140mm silence fan with smart temperature controlling feature. The fan supports 0 RPM to achieve 0 noise based on the scenario.
RTX Ready
Full Modular Cabling
80 PLUS Gold Certified
High Temperature Resilience
MWE Gold V2 1050 series is able to push its temperature resilience to 50 degree Celsius safely. Such a high threshold greatly improves what's possible to accomplish with the unit and your system in general. Overclocking and other high intensity applications become way more accessible when the system's power supply unit can take the heat.
10 Year Warranty
The MWE Gold V2 1050 comes with a standard 10 year manufacturing warranty from the date of purchase.
PSU Calculator
