THERMAL PAD
Cooler Master's new Thermal Pad is an innovative solution to device cooling for a vast range of your electronic devices and components.
Thermal Pad baru dari Cooler Master adalah solusi inovatif pendinginan untuk berbagai perangkat dan komponen elektronik Anda.
13.3w/mK thermal conductivity for rapid cooling, capable of drawing high levels of heat.
Safe and simple formula with electrically insulated and heat resistant properties to prevent hardening.
Provides seamless and secure contact between surfaces.
Electronic devices, motherboards, components (CPU, GPU, USICS, Hard Drives, Disk Drives, IGBT module), laptops and various products requiring cooling.
