for MasterCase5, 6, MC500, MC600, H500P and H500M
Tempered Glass Side Panel
Tempered Glass Side Panel for MasterCase5, 6, MC500, MC600, H500P and H500M
Overview
The tempered glass side panel bring a premium touch to your chassis and allow to highlight any system from water cooling advanced build up to the simpliest configuration.
The quality of the glass guarantee a long life durability and the bracket design hold the side panel to prevent any falls.
Compatible with:
• MasterCase 5 Series
• MasterCase 6 Series
• MC500 Series
• MC600 Series
• H500P & H500M
Unique Bracket Design
Can hold the tempered glass from falling down while installing or removing.
Toughened Dark Black or Light Grey Tinted Glass
It provides 3 - 5 times more strength than regular glass because of the 4mm thickness.
Only see the subtle light effects inside your system.
The tempered glass can be choosen in 2 tinted colors : Light Grey or Dark Black
Easy Secure Design
Lock or unlock the glass side panel easily with a coin.
