Choose The Most
SickleFlow 120 ARGB 3in1
Melanjutkan seri SickleFlow 120, Cooler Master memperkenalkan model baru dengan fitur desain baru yang kinerja ditingkatkan.
NEXT GENERATION OF SICKLEFLOW FANS
SickleFlow 120 ARGB, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
UPDATED LIGHTING DESIGN
Featuring eclipse-mode lighting and enhanced lighting effects.
ENHANCED FAN FRAME
NEW BEARING SEALANT
Improve dustproof properties as well as prevent sleeve lubricant from leaking.
NEW BLADE DESIGN
SECURE CONNECTION
Includes Addressable RGB connector clips to ensure a secure connection
Reduced noise
SICKLEFLOW 120 3 IN 1
SickleFlow 120 3in1, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
ADDRESSABLE RGB CONTROLLER
With Included Addressable RGB Controller, You can choose your favorite color easily. It also support lighting RESET button of Case.
