Reaching New Brights
MasterBox 520 Mesh
MasterBox 520 Mesh adalah casing ideal untuk memenuhi kebutuhan gamer pemula dan veteran dengan kelengkapan fitur dan kemudahan pemasangan.
Performance
FINEMESH PERFORMANCE FRONT PANEL
Large mesh intakes offer unrestricted airflow and stellar thermals for demanding systems.
Colors
AVAILABLE IN BOTH BLACK & WHITE
Choose the color that best matches your setup!
Design
Removable Top Panel
The top panel is entirely removable for improved access and easy installation of cooling solutions such as fans and radiators.
Fans
Three CF120 ARGB Fans Included
Pre-installed CF120 ARGB fans provide ample airflow, ensuring low temperatures, high performance, and eye-catching aesthetics during even the most intense gaming sessions.
Screwless & Tool-Free TG Side Panel
The tempered glass side panel is secured with pins for easy removal, facilitating quick, easy installation.
Customization
Versatile Cooling Options
Supports up to seven 120mm fans and dual 360mm radiators on the top 140mm and front panel.
(RE)Movable HDD Cage
The HDD cage is completely (re)movable for improved access during assembly and system upgrades.
ARGB/ Fan Hub Included
The included controller allows users to manage systems lighting independently from the hardware configuration and provides the user with 4 additional fan headers in case of need.
Upgraded Removable Dust Filter Bracket
The bottom dust filter bracket is robust and locked sturdily in place during travel, remaining easy to remove for cleaning purposes.
Rich Connectivity
The 1/0 panel comes with a USB 3.2 (Gen 2) Type-C port, a USB 3.2 (Gen 1) Type-A port, and one 3.5mm (audio + mic) headset jack.
The ventilated PSU cover supports both active and passive cooled PSUs installed in multiple orientations.
Hardware Compatibility
MasterBox 520 Mesh is natively compatible with ITX, M-ATX and ATX motherboards.
E-AT motherboards, such as SSI-CEB models, are compatible with dimensions up to 12" x 10.7".
