POWERFUL YET AFFORDABLE
Hyper 620S CPU Air Cooler
Cooler Master is advancing the Hyper Series legacy with the debut of the 6 heat pipe Hyper air cooler – the Hyper 620S.
Controllable Lighting
Automatic ARGB
Intuitive LED detection automatically provides default ARGB spectrum lighting.
6 Nickel-plated Heat Pipes
Uniform heat pipes featuring a nickel-plated base with complete coverage for even, efficient heat transfer.
Dual Tower Heat Sink
High-performance Cryofuze
Minimal Height
Compatible with most case requirements thanks to low-profile heat pipes and a total height of 154.9mm.
