The Legend Continues
Hyper 212 Halo White
Cooler Master meluncurkan kembali Air-Cooler yang paling diakuinya dengan produk terbaru Hyper 212 Halo White.
MF120 Halo²
Improved air flow with stunning dual loop ARGB lighting. Redesigned hybrid frame maintains stability without sacrificing fan operational real estate.
ENLARGED FAN BLADES
Increased fan blades to deliver better air flow and cooling performance.
ARGB AUTO DETECTION
Intuitive LED detection automatically provides default ARGB spectrum lighting or full ARGB Gen 2 customization via 3-pin header connection.
BLACK ALUMINUM
TOP COVER
Clean modern design featuring matching aluminum top cover with signature logo
JET-BLACK HEAT PIPES
4 heat pipes with black finish provide exceptional cooling and aesthetics
Wide Range Compatibility
Compact 154mm height designed for wide chassis compatibility without sacrificing performance
UPGRADED INSTALLATION BRACKETS
Redesigned brackets simplify installation on the latest available platforms
CPU COMPATIBILITY
