Quiet Colorful Cooling
CF120 ARGB
Cooler Master’s CF120 ARGB is the most well rounded fan solution for your case and chassis.
CF 120 ARGB
Cooler Master’s CF120 ARGB is the most well rounded fan solution for your case and chassis. The frame is constructed with reinforced PBT for stability, with air balance fan blades for high airflow and cooling performance. The flexible mounting system is anti-resonance for noise minimization. The CF120 ARGB is cost effective case fan for excellent cooling capabilities while also giving you vibrant ARGB lighting to add the touch of color to your build.
Air Balance
Fan Blades
Noise
Minimization
Addressable RGB Lighting
Vibrant ARGB lighting to add the touch of color to your build, Compatible with major Motherboards.
