Caliber X2 | Memory Foam Gaming Chair
Command and Conquer
Building on the legacy of the Caliber X1 Gaming Chair, the Caliber X2 features a new design with upgraded comfort and ergonomics.
Perfect for Any Scenario
Designed specifically for those who spend extensive amount of hours staying seated for work as well as play, the Caliber X2's clean, professional aesthetic with a full array of ergonomic features makes it the perfect addition to your setup.
Choose Your Style
Caliber X2 is available in Ash Gray or Shadow Black colorways to fit your style.
Adaptive Ergonomics for Your Comfort
Caliber X2 features a larger headrest and lumbar support for an improved ergonomic fit for all users. By increasing the size, it ensures ample support for various body types where it’s needed most.
ALL-DAY COMFORT
Caliber X2 features ultra-soft yet dense memory foam that dynamically contours around you for all-day comfort.
ENHANCED SEAT BASE
Caliber X2's seat base has been upgraded to a thicker and denser foam for an even more comfortable sitting experience during long work or play sessions.
Unibody Cold Molded Foam
Cold-molded foam offers superior shape retention and evenly-spread support, making it a premium, long-lasting, and comfortable choice for high-quality chairs.
UPGRADED MATERIAL
The Caliber X2 now features an all-new, fully blacked-out synthetic performance PU for the perforated patches, matching the high-quality PU leather used on other parts of the chair.
PRECISION GAS LIFT
Caliber X2 still uses the proven and tested Precision Class 4 Gas Lift for precise, reliable, height and lock adjustment.
75MM SILENT CASTERS
Large premium caster wheels roll exceptionally well on all surfaces while producing less noise than traditional casters.
4D ARMREST
Caliber X2 features a premium 4D armrest with lift, swing, forward and sideways panning.
Fit for Any Occasion
Caliber X2 continues to offer a 180° full-reclining experience.
Cooler Master Exclusive Design
Featuring a design and colorway unique to Cooler Master's own identity, Caliber X2 is an extremely stylish chair that is sure to match your setup.
