PRECISE SILENT POWER
X Silent Edge Platinum 850 Power Supply
The X Silent Edge Platinum also includes ATX 3.0 support, a durable 12VHPWR cable, reliable, industrial-grade Infineon IC chips, fully modular cabling
Precise Silent Power
Engineered with a fanless design and industrial IC components, X Silent Edge Platinum features out Heat Pipe Dissipation Patent, ensuring quietness for even the most noise-sensitive environments.
No Fan, No Dust
Equipped with a heat pipe and an innovative modular thermal structure, our design enhances thermal efficiency, essential for the low-temperature rise of key components and the ultra-quiet fanless operation.
Patented Copper-Aluminum Heat Dissipation
Active Bridge Rectifier Boosts Efficiency 2%
The Active Bridge Rectifier, equipped with the Infineon CoolMOS, marks a significant advancement in power efficiency. This innovative combination not only conserves electricity, but also significantly reduces power loss, outperforming traditional bridge diodes. It's an ideal solution for users seeking eco-friendly, high-efficiency power supply units.
Digital Power Management System & MasterCTRL
Equipped with MCUs and Integrated with MasterCTRL software, our reliable PSU meticulously monitors temperature, current load and efficiency in real-time, offering precise and direct oversight.
ATX 3.1 Support & A Durable 90° 12v-2x6 Cable
Includes ATX 3.1 support and a 90° 12V-2x6 connector featuring more reliability, higher electrical durability, improved safety, and capable of bringing up to 600W to your GPU.
PSU Calculator
