YOUR PLAY-WORK-MOVIE SOLUTION
GP2711 delivers superior images and accurate colors with a more responsive overall experience making it perfect for work and play.
The Tempest GP2711 is a marvel of technology and is tailored to meet the high standards of avid gamers and demanding creative professionals.
Featuring Cooler Master's unique heatsink and a thermal back cover design. the GP2711 ensures enhanced cooling without the need for fans. This reduces the main chip's temperature by “5°C, extending product durability by 30%. Experience unmatched temperature stability during long work or play sessions. Plus, benefit from our 4-year warranty.
Our VA panel, with the latest Mini-LED technology, provides an ultra-high contrast visual experience in HDR. In HDR+ local dimming mode, it can achieve over 3,000,000:1 contrast*.
* Based on LAB testing
While standard Mini-LED monitors suffer from low contrast and pronounced halo effects, the GP2711 offers high contrast with minimal halo problems.
The VA panel with mini LED in the GP2711 let you see the real world through the screen. Offer 3000:1 contrast ratio and HDR of 3,000,000:1 using local dimming. This far outpaces the average IPS monitor contrast of 1000:1 and no HDR. Up to 1000 nits of brightness make for sharp clarity in bright areas and rich details in dark areas.
Using a quantum dot enhancement film, the GP2711 offers brighter, more vibrant colors with exceptional color reproduction, covering 93.5% of the Adobe RGB and 95% of the DCI-P3 color gamut ranges.
The QHD resolution not only offers sharper visuals, but also provides more screen space, making multitasking a breeze and gaming more immersive.
GP2711 utilize a fast 165z panel along with an ultra-responsive 1ms (MPRT) / less than 4ms GtG response time that is carefully calibrated for optimal overdrive performance.
FreeSync ensures smooth, lifelike gameplay that accurately reproduces a level of realism to everything you play. By synchronizing the frames outputted from the GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is smoother than ever.
With extensive color gamut support, including DCI-P3 and Adobe RGB, the GP2711 is ideal for color-critical tasks.
Our monitors are hand-calibrated at the factory, promising impeccable color reproduction with a delta E ≤ 2*. Witness content as the creator envisioned.
* sRGB mode
With TUV Certificate hardware-enabled Low Blue Light Mode and Flicker-Free technology, the GP2711 is gentle on the eyes, minimizing fatigue as you get more work or gaming done.
Connect your devices with I/O ports consisting of:
• HDMI 2.0 x 2
• DP 1.4 x 1
• Type-C x 1 (DP Alt Mode & PD15W)
• USB Type-B 3.0 x 1
• USB Type-A 3.0 x 2
• 3.5 mm Audio Out x 1
• Speaker 2W x 2
