REFRESH YOUR STYLE
Q300L V2 Mini Tower PC Case
The Q300L V2 delivers a new perspective on the small form factor build experience by pushing the boundaries of what a micro-ATX case can do and be.
New Design
Magnetic Dust Filter
The redesigned dust filter keeps your PC breathing easy
with a refreshed patterned design.
Ports & Slots
USB 3.2 GEN2 2x2 Supported
USB 3.2 Gen 2x2 Type C port built into the 1/0 panel with data transfer speeds up to 20Gbps.
Design
Clean Routing Space
Air Flow
Excellent Thermal Performance
Design
Edge To Edge Tempered Glass Side Panel
Show off your build through the 4mm-thick tempered glass side panel, easily installed with thumbscrews.
Multiple Positioning Options
The case can be put in vertical or horizonal position.
FAN AND RADIATOR SUPPORT
The front supports up to two 140mm fans and up to a 240mm radiator. The rear supports a 120mm fan or radiator and the top two 120mm fans. All to ensure you don't have to compromise on performance.
COMPONENTS CLEARANCE
The Q300L V2 case supports CPU coolers up to a height of 159mm, graphics cards up to a length of 360mm, and power supplies up to a length of 160mm.
