New
Max Performance, Minimalist Design
NCORE 100 AIR
Latest Gen GPU Compatiblity
Ultra-Small Footprint
Extendable Frame Design
Open and Toolless Frame Design
Thermal Efficient Layout
Available in Black and White
The Compact Case for Powerful PC
Ncore 100 Air is designed with space-saving and performance in mind. With its small footprint and minimalistic design, Ncore 100 Air is versatile for gamers and content creators. The Ncore 100 Air offers ample space for the latest-generation GPUs, while its thermal layout ensures efficient airflow for optimal cooling.
LATEST GEN GPU COMPATIBILITY
Supports triple-slot graphics cards up to 336 mm in length. The PCIe slot is adjustable to accommodate cards up to 356 mm, ensuring compatibility with the latest-generation GPUs.
EFFICIENT THERMAL LAYOUT
The Ncore 100 Air layout has been meticulously designed to offer the most efficient thermal layout. This layout pulls in air from the standing sides of the case, which are its largest surface.
PREMIUM ALUMINUM PANEL
An anodized aluminum shell makes the Ncore 100 Air stand out as a desktop work of art.
ULTRA-SMALL FOOTPRINT
The Ncore 100 Air is super compact, with a footprint about the size of a small booklet.
EXTENDABLE FRAME DESIGN
The Ncore 100 Air has a compact volume of just 14.7L; however, its frame is designed to expand up to 16.4L when needed.
OPEN AND TOOLLESS FRAME DESIGN
Based on Cooler Master’s ‘Make It Yours’ and staying true to our audience, the open frame design make it easy to build or upgrade the PC. Even the cover features tool-less removal for maximum accessibility.
