![](https://a.storyblok.com/f/281110/1920x850/71045f09e4/mwe-gold-1050-v2-atx3-main-1.png/m/1700x0/smart)
80 PLUS Gold Efficiency
140mm Silent Fan
High Temperature Resilience
Fully Modular Cabling
10 Year Warranty
La fuente de poder MWE Gold 1250 - V2 ATX3.0 de Cooler Master ofrece eficiencia 80 PLUS Gold, un silencioso ventilador de 140 mm, 2 conectores EPS
140mm Silent Fan
10 Year Warranty
Cooler Master took the initiative and continuously developing our first ATX3.0 Power Supply lineup. Compliant with ATX3.0 standard and 12VHPWR connectors, the MWE Gold 1050/1250 - V2 ATX3.0 can fully support the peak power drawn by the 40 series RTX graphic cards and whole system.
The fully modular version of the MWE Gold 1050/1250 - V2 ATX3.0 comes with a set of flat black cables that can be customized to each user's individual needs. It's designed for easy cable management that each system only needs to include the cables required. This unused space within the chassis allows for reduced clutter, better airflow and aesthetic, thereby improving your system's overall cooling.
