Bring On The Light
MasterFan MF120 HALO² Case Fan
Cooler Master has redesigned our Dual Loop LED series fan to introduce the new MasterFan MF120 Halo².
VIBRANT ADDRESSABLE GEN 2 RGB
50% MORE LIGHTNING
Larger LED rings increase lighting by 50% for even more vibrant lighting.
HYBRID FRAME DESIGN
Redesigned frame structure and corner dampers maintain stability without sacrificing fan blade area for better performance.
LARGER FAN BLADES
Air Balance fan blades increased by 10% in size deliver stronger air flow and cooling performance.
IMPROVED COOLING PERFORMANCE
Fine tuned P-Q Curve increase air flow and pressure while being even more quiet than its predecessor.
