240-280MM
LIQUID COOLERS
18.25L
ULTRA-SLEEK DESIGN
120MM
BOTTOM FAN
COMPREHENSIVE GPU SUPPORT
Includes vertical mounting options, a custom PCle 4.0 riser cable, and a support bracket for GPUs up to 356mm in length and 160mm in height.
Step into a world of elegant and sophisticated functionality with the NR200P V2. The V2 showcases features typically reserved for high-end
A USB 3.2 Gen 2x2 Type C port is built into the 1/0 panel with up to 20Gbps transfer speeds.
All external panels are secured with pins for easy removal, facilitating quick access to the internals without the use of tools while a removable GPU panel simplified the installation process.
An NCORE redesign provides a sleek take on maximizing cooling performance and style simultaneously.
