30th Anniversary Edition
MA824 Stealth 30TH Anniversary Edition carries the Stealth identity with total blackout accents and design, in addition to the 30th Anniversary logo and silkscreen print. With an impressive 8 heat pipes & dual tower design, the MA824 Stealth delivers unmatched performance in it’s class. Upgraded with the 30th Anniversary 120mm Mobius Fan, the 135mm fan provide absolute cooling performance in a Push – Pull configuration. The MA824 Stealth is bringing performance ready to overshadow it’s competition.
8
HEAT PIPES
Cooling System
Full
Coverage Base
The full coverage nickel plated copper base provides seamless
contact and complete coverage to minimize heat zones.
Special Edition
30TH
ANNIVERSARY DESIGN
Tech Specs
& Downloads
Performance
Dual Tower
Redesigned dual tower maximizes performance and surface area with optimized fin density and thickness.
Performance
Dual Mobius Fan
Dual Mobius fans with balanced air flow and pressure perfect the push-pull setup for maximum heat dissipation.
CPU Compatibility
