![](https://a.storyblok.com/f/281110/1920x850/3242514587/hyper-h410r-rgb-main-1.png/m/1700x0/smart)
Hyper H411R
With RGB LED PWM Fan
Precise Air Flow
Direct Contact Technology
XtraFlo PWM Fan
Compact Size
Snap and Play
The Hyper H410R RGB, a new member of the longstanding Hyper Series, is an affordable, compact and high performance air cooler...
Precise Air Flow
XtraFlo PWM Fan
Compact Size
Snap and Play
4 heat pipes with Exclusive Direct Contact Technology providing effective and excellent heat dissipation
Wide speed range PWM fan that comes with RGB LED lighting
The wired RGB LED controller allows for customizable colors and effects with just the touch of a button
head to go WIRED RGB CONTROLLER C10
Precise stacked fin array decreases airflow resistance which allows for cooler air flow into the heatsink
Comes with RGB LEDs and wide speed range can be fine-tuned for maximum cooling performance or silent operation
Tool-free mounting system ensures hassle-free installation. Universal retention brackets are compatible with latest Intel and AMD socket CPU.
