Hyper 212 Spectrum V3 CPU Air Cooler
Cooler Master is releasing the Hyper 212 Spectrum V3, a redesigned addition to its popular 212 Spectrum predecessor.
HYPER 212 SPECTRUM V3
ARGB Auto Detection
Nickel Plated Heat Pipes
Wide Range Compatibility
Upgraded Installation Brackets
ARGB Auto Detection
Intuitive LED detection automatically provides default ARGB spectrum lighting or full ARGB customization via 3-pin header connection.
SPECTRUM ARGB FAN
Performance spectrum fan with ARGB compatibility with Asus Aura, ASRock RGB, Gigabyte and MSI RGB motherboards.
NICKEL PLATED HEAT PIPES
4 heat pipes with silver nickel plated finish provide exceptional cooling and aesthetics
UPGRADED INSTALLATION BRACKETS
Redesigned brackets simplify installation on the latest available platforms
CPU COMPATIBILITY
